KennethAlv
Apr 27, 2020Tutor
RBS50 connectivity issues
Hi, I'm a Orbi owner for almost 2 years without a single issue. Last friday I began to experience connectivity issues on my satellites. When I'm connected on either of the satellites if I run a speed...
Apr 27, 2020Guru - Experienced User
Has a factory reset and setup from scratch on the RBR been performed since last update?
- KennethAlvApr 27, 2020Tutor
like I said before, this is a almost 2 year setup. The problem begin on last Friday and is apparently with the satellites because the issue is not present when I'm connected to the router.
I already do a factory reset.
- FURRYe38Apr 27, 2020Guru - Experienced User
On the RBR as well?
on all three devices
