KennethAlv
Apr 27, 2020Tutor
RBS50 connectivity issues
Hi, I'm a Orbi owner for almost 2 years without a single issue. Last friday I began to experience connectivity issues on my satellites. When I'm connected on either of the satellites if I run a speed...
KennethAlv
Apr 27, 2020Tutor
like I said before, this is a almost 2 year setup. The problem begin on last Friday and is apparently with the satellites because the issue is not present when I'm connected to the router.
I already do a factory reset.
Apr 27, 2020Guru - Experienced User
On the RBR as well?
- KennethAlvApr 27, 2020Tutor
on all three devices
- FURRYe38Apr 27, 2020Guru - Experienced User
KennethAlv wrote:on all three devices
Did you make sure Beamforming and WMM was enabled on the RBR?Check to see what speed your mobile devices are connected with the RBR and RBS. Use wifi sweetpots app for this.
I would power OFF The RBS first and check with the RBR. Then power ON 1 RBS then check the speed with your device.
- Retired_MemberApr 27, 2020
Something happened on Friday.
