AFD
Jan 29, 2021Luminary
RBS50 Connectivity problems and Issues
I have the same problem with almost the same symptons that reported in the following thread https://community.netgear.com/t5/Orbi/RBS50-connectivity-issues/m-p/1902652 Just starting , nothing...
Jan 29, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
There is more resent version of FW past v4:
Which you can manually downlaod and manually update the RBR first then RBR lastly:
AFD
Thanks for answering - Im going to answer all your questions , but a detail from my side (im in Argentina not in the US)
All the mentioned environment was ruinning perfecrtly weel since 3 years ago . Without any change in distance , connectivity , etc
Answering your questions
1 - What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Provider : Movistar (Telefonica from Argentina)
ModemModel Firmware
| : Askey |
| : RTV9015VW |
| : AR_RTK_V10.1.3o |
Do you think that some related problems from the ISP can cause this issues in the Satellite behaviour?
2 - What is the size of your home? Sq Ft?
2150
3 - What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
About 32/34 feet (no problems until now) (??)
4 - What channels are you using? Auto?
| 2.4GHz Channel: | Auto |
| 5GHz Channel: | 48 |
5 - Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Going to test and lets see
6 - Any Wifi Neighbors near by?
Yes
7 - If so, how many?
17 Wifi Neighbors (checked Fing App) at 2.4
8 - Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Going to test and lets see (another engineer recommends me in the past to keep all this features as disabled) but Im going to test.
9 - Try Disabling Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes
Actual Settings
Armor and Circle are disabled
Daisy Chain is enabled
20/40 Mhz coexistence is enabled
Fast Roaming is desabled (not flaged)
IPV6 is Disabled
Preambled mode is automatic
10 - Has a factory reset and setup from scratch been performed since last FW update?
No factory reset done since last update . Everything was perfect
Please your recommendations in how to proceed (all the changes by once in the actual firmware) ? Change the firmware manually and then start with parameters change?
Thanks for helping Im going to read carefully the users experience you sent me . to see where to start . \
Im terrified because you know Im too far in order to solve any problem related with Orbi whoch used to works perfectly .
Anyway lets see
