jvetro
Jan 27, 2025Tutor
RBS50 Continuously flashing white
Good day, this morning my RBS50 satellite was flashing White, with no connectivity, wired or wirelessly. It is connected to an RBR50 with a wired backhaul. I tried performing a 30-30-30 reset, with...
jvetro
Jan 27, 2025Tutor
I removed the Satellite from my RBR50 and tried synching it again, however the light will not go to solid white as the instructions indicate.
How to perform a factory reset on the RBS50? As mentioned, I tried a 30-30-30 reset as well as holding the reset button for 60 seconds.
The light on the top continuously flashes white, no other colour, just a steady pule of white, no matter what I do. Once it powers on it immediately flashes white.
I was able to get it into TFTP mode and I was able to flash the same firmware as the router, however, it is still pulsing white.
Jan 27, 2025Guru - Experienced User
I'd try resetting the RBR. Press the reset button for 15 seconds then release. Do same for the RBS. Watch the back power LED, should be blinking AMBER then turn GREEN. When it goes GREEN power OFF The RBS. After the RBR is reset, wait before you being to setup from scratch with the web browser. Power ON the RBS. Give about 5 minutes. The RBS should auto connect to the RBRs default SSID while waiting for the setup to begin. If not, walk thru the setup routine with the RBR and see during the setup routine during the RBS detection if it's seen there.
- jvetroJan 27, 2025Tutor
I'll have to give that a try later on tonight.
A bit confused how resetting the RBR50 will resolve the RBS50 issue from flashing white.
BTW, when I was trying to reset the RBS50, the power LED would never go to Amber, it would only flash red a few times then to green.
