godspeed
Dec 11, 2017Apprentice
RBS50 continuously reboots itself
I bought the RBK50 recently, and have had it running in AP mode for about 2 weeks so far. Reason i run in AP mode, is that the router functionality of the Orbi is missing many features that i am used...
godspeed
Dec 13, 2017Apprentice
Quick update:
This morning when i logged onto the satellites debug.htm page, i noticed that it had rebooted itself (system uptime was only a few hours, compared to the routers uptime of 17 hours). There was an event in the router's log (Advanced -> administration -> logs) that corresponds to the satellite reboot:
[WLAN access rejected: incorrect security] from MAC address 96:3b:XX:XX:XX:XX, Wednesday, December 13, 2017 05:24:14
this MAC address happens to be one of the MACs used by the Orbi system. I discovered this by turning on the Debug Log capture and searching for that MAC address, and found it referened a few times as ATH01.
I will continue monitoring the logs to see if the next satellite reboot also has a correponding "WLAN access rejected" message. My guess is that the satellite rebooted because the internal encrypted connection between the router and satellite malfunctioned, causing the satellite to reboot?
- loomis1975Dec 13, 2017Luminary
Have you opened a Support ticket?
It sounds like you have a lot of data to offer Support about this issue. You might be well on your way to a replacement satellite from Netgear if nothing else.
Only thing I can think of is to try to Master Reset the satellite and then Resynch the satellite to the router, although if it is a match pair from factory, it might resynch back up by itself, but manually synching via pressing the buttons can't hurt.
