Yatheesh
Nov 23, 2021Initiate
RBS50 Does not connect to Internet
Hi, I have a RBR50 Orbi modem with RBS50 extension satellite. Since morning, RBR50 base station is working fine and provides internet connection to attached devices, however satellite does not. Bo...
Nov 23, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Be sure the RBS FW is updated to same version as whats loaded on the RBR.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
