JmarcSyd
Oct 16, 2022Guide
RBS50 doesn't fail over to wireless backhaul when disconnecting wired backhaul
I am using an RBR50 with one RBS50 satellite. The wireless backhaul is working well however I've recently moved to a wired backhaul with a switch between the two units. This works well too. I was...
- Oct 19, 2022
Thanks for the suggestion FURRYe38 however it turns out that the hallway switch being in the middle of the wired backhaul is indeed causing the issue as the RBS50 still thinks it's connected to the RBR50. If I disconnect the RED cable on the diagram, the fail over to wireless backhaul happens within 3 minutes, then when I reconnect it, it switches back to the wired backhaul. But if I disconnect the GREEN cable, nothing happens, nada.
Ideally I'd need to bypass the hallway switch altogether and connect the green cable directly from the RBR50 to the RBS50 but for practical reasons (i.e. cabling in ceiling) I can't so I'll live with this.
As I said at the beginning it's not a big deal as everything is working well but it's good to know that ideally a wired backhaul should be a direct connection.
Thanks!
JmarcSyd
Oct 16, 2022Guide
I think about 10 minutes.
JmarcSyd
Oct 17, 2022Guide
Here's my little network diagram that answers the questions.
- plemansOct 17, 2022Guru - Experienced User
What switches are you connected to?
What modem/gateway do you have the orbi connected to?
- JmarcSydOct 17, 2022Guide
The switches are TP-Link TL-SG105 (gigabit unmanaged) and the modem is an Arris cm8200 provided by NBN in Australia (coax HFC network, 1 Gb / 50 Mbps).
- plemansOct 18, 2022Guru - Experienced User
I'm wondering with the setup if the satellites are connecting to each other and thinking one will switch to wireless backhaul since they're still connected and its causing a loop. What happens if you disconnect one of them from the switch while you're testing this?
Btw the diagram was nicely done.
