BThis
Apr 14, 2020Aspirant
RBS50 drops connections to Ring cameras
Two Ring wireless solar charged cameras, an original Stick Up Cam with solar panel and a newer solar-powered Spotlight Cam both lose their connections. When I set them up they say the connection is g...
- Apr 14, 2020
There is a l-o-n-g post about how to connect Ring products. You can search in the upper left corner of the forum web page. I would look for "Ring".
BThis
Apr 15, 2020Aspirant
I don't know which Ring post CrimpOn was referring to. I found a very long string of posts with various fixes but some were years old and subsequent comments said that problem had been fixed... In the meanwhile, I moved the Ring Chime to a plug closer to the camera and got a better signal. When I previously had it in that plug, in the ceiling by the garage door opener, it would not connect to Wi-Fi. But I realized that was before I had ORBI. The RBS50's signal is strong enough to reach it there. Now it's closer to the Spotlight Cam, so both signals are better.
So far, so good. Per my original post, another camera has a similar problem. It's working now, but I may have to do more digging to find the post CrimpOn is referring to.
Apr 15, 2020Guru - Experienced User
Can review this one:
BThis wrote:I don't know which Ring post CrimpOn was referring to. I found a very long string of posts with various fixes but some were years old and subsequent comments said that problem had been fixed... In the meanwhile, I moved the Ring Chime to a plug closer to the camera and got a better signal. When I previously had it in that plug, in the ceiling by the garage door opener, it would not connect to Wi-Fi. But I realized that was before I had ORBI. The RBS50's signal is strong enough to reach it there. Now it's closer to the Spotlight Cam, so both signals are better.
