Wowzors
Aug 22, 2019Aspirant
RBS50 Drops Internet and Router Connection
I bought the RBK53 from costco in late April 2019. Everything was setup and updated to the latest firmwares (2.3.5.30) and ran perfectly fine for around 2 and a half months. The setup is currently RB...
Aug 22, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What happens if you swap RBS places.
The basement is the the best place for the main Orbi router. The main floor is preferred...
Wowzors wrote:I bought the RBK53 from costco in late April 2019. Everything was setup and updated to the latest firmwares (2.3.5.30) and ran perfectly fine for around 2 and a half months. The setup is currently RBR50 connected to an Arris SB8200 with my ISP being Comcast Xfinity Gigabit speed. The router is located in the basement, with one satellite on the main floor and the other satellite on the second floor. Every Satellite and Router is on the latest firmware.
The issue only occurs on my main floor satellite, it will run fun for an extended amount of time and then one day it will disconnect from the router and lose internet connection, after it does this once it will continue to do so frequently until I factory reset the satellite, at which point it will run fine for a random amount of time until the process repeats. The second floor satellite never exhibits this behavior, I initially belived it was due to faulty backhaul ports but I unplugged all devices from the satellite months ago and its has continues to exhibit this behavior.
I opened a case on the Netgear website on June 28th and have updated it twice with notes since, yet a netgear representative has yet to respond.
