Wowzors
Aug 22, 2019Aspirant
RBS50 Drops Internet and Router Connection
I bought the RBK53 from costco in late April 2019. Everything was setup and updated to the latest firmwares (2.3.5.30) and ran perfectly fine for around 2 and a half months. The setup is currently RB...
Wowzors
Wireless Backhaul, I am unable to run a wire to the router for the satellites. I should mention, when i do the factory reset with the pin in the back of the satellite it seems the satellite always reconnects to the router without me having to readd it. To me it doesnt appear to be fully resetting even though I hold the pin down until it flashes orange on the back.
Aug 22, 2019Guru - Experienced User
You might try this, power OFF the RBS. Go into the RBRs web page and select disconnect from the connected clients list. The RBS should be listed here. If it is, disconnect it and then reboot the RBR. Then power ON the RBS and hit the reset button on the back of the RBS for 15 seconds then let go. No longer or no less. The RBS should get a slow pulsating ring LED on top. Then hit the sync button on the RBR and RBS...
