Wowzors
Aug 22, 2019Aspirant
RBS50 Drops Internet and Router Connection
I bought the RBK53 from costco in late April 2019. Everything was setup and updated to the latest firmwares (2.3.5.30) and ran perfectly fine for around 2 and a half months. The setup is currently RB...
dano99
Dec 27, 2019Aspirant
I had same issue with my RBS50. My connection was WIRED so I was baffled how it could lose its connection. Support had me reset it, update the firmware and after a few days it dropped again.
I had to pay $15 to send the satellite to Netgear. I am not happy about that as it should not cost me to replace a defective satellite that was only 2 months old.
If anyone can shed some light as to why a wired satellite would repeatedly drop its connection, I would love to understand this problem.
Dec 27, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
Armor, Circle, Daisy Chain(Disable for wired RBS), Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
dano99 wrote:I had same issue with my RBS50. My connection was WIRED so I was baffled how it could lose its connection. Support had me reset it, update the firmware and after a few days it dropped again.
