rckingsley's avatar
rckingsley
RBS50 Firmware update 'No Internet'
I have an RBR50 (just updated to V2.7.4.24), and am attempting to update my RBS50.  Up until today, everything has been working fine, but now (after rebooting both routers - several times), the Inter...
  • FURRYe38's avatar
    Aug 12, 2022
    Did you update the RBS first, then the RBR lastly?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
