Cahall123
Jun 27, 2020Initiate
Rbs50 firmware V2.1.4.16_1.0.0.11 upgrade
I have a Verizon bought Orbi RBS50 router and satellite and an external RBY50 satellite. I am trying to upgrade the Verizon router and Satellite that are still on V2.1.4.16_1.0.0.11 but manual fails w...
Cahall123
I spent almost 4 hrs on the phone their useless tech department had no idea they loaded What looks like Verizon specific firmware onto the routers, they claim not to support the routers (even though they recommended and sold it to me) and claimed that only Netgear could help which appears not to be the case. When I received it they promised if I ever left Verizon that they would send a link to remove their firmware which they are now denying......... All around terrible customer support and has left me with a low firmware expensive paper weight router
Jun 28, 2020Guru - Experienced User
You can try this:
Download both RBS and RBR FW files...
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
