Frankis843
Nov 27, 2024Aspirant
RBS50 Firmware very old, can't update
I am having trouble updating my RBS50's. When I try to do it manually it says the Firmware File is incorrect. I have searched and have been unable to solve this issue. Can anyone help? Thanks in...
- Nov 28, 2024
That was it. I first updated them each around 4 times each to finally get to everything to 2.7.4.24!
Nov 28, 2024Guru - Experienced User
try going the version right before that version. Sometimes you need a stepped process or something has changed in the process.
Frankis843
Nov 28, 2024Aspirant
- plemansNov 28, 2024Guru - Experienced User
glad that fixed it! might mark it solved so others aren't still trying to fix it. Also, a backup is a good option.
