mask207
Jun 05, 2022Initiate
RBS50 flashing red power light and pulsing white
Thanks to a car taking down a power line about a block away, we had a power surge about a week ago, and one of my RBS50 satellites has been down since then. In the iOS Orbi app and the orbilogin.com ...
Jun 05, 2022Guru - Experienced User
Just downloaded the firmware and extracted it without issue. Not sure your exact process you're using is thats giving you that error.
Did you try simply factory resetting and reinstalling the satellite?
Sometimes it helps to hardwire it into the router for the initial syncing.
