Roadrunner505
Jul 06, 2021Tutor
RBS50 Incorrect Firmware Uploaded (v2.7.3.22)
I am trying to upgrade my satellite to the new firmware version V2.7.3.22 (article ID 000063811, https://kb.netgear.com/000063811/RBR50-RBS50-Firmware-Version-2-7-3-22) . However, I'm getting an er...
- Jul 06, 2021
NG has now corrected the file. Verified corrected.
Roadrunner505 wrote:I am trying to upgrade my satellite to the new firmware version V2.7.3.22 (article ID 000063811, https://kb.netgear.com/000063811/RBR50-RBS50-Firmware-Version-2-7-3-22) . However, I'm getting an error saying that the firmware version is incorrect. When I open the zip file, the .img file is "RBR50-V2.7.3.22.img". Is the file name wrong or was the wrong file uploaded by Netgear?
thatkid2diesel
Jul 06, 2021Initiate
I tried to upload the new file that you linked to, I still get the error the firmware file is incorrect. Trying to upload to the Satellite first. File name inside the RBS50-V2.7.3.22 is still RBR50-v2.7.3.22.img. Release note file is RBS50-V2.7.3.22
daboss54
Jul 06, 2021Aspirant
not working here either no correction from Netgear
- FURRYe38Jul 06, 2021Guru - Experienced User
This isn't working for you at all?
Might try powering OFF your ISP modem/ONT and router for 30 seconds then back ON. Clear out all browser caches as well.
Is odd that some are getting the file and some don't. I was able to get this after getting home from work today.
daboss54 wrote:not working here either no correction from Netgear
- daboss54Jul 06, 2021Aspirant
can you send the corrected file for rbs50 thanks
I'm using Opera GX. I just noticed that while on my Mac Laptop, the browser downloaded the wrong sized file. I selected the file again from the same link and it then downloaded the right sized file. Can you try this as well? Try Opera GX using the link from here:
Just select the RBS50 file a couple of times and see if it will download the right size file. The file should be 23MB, Not 44MB.
