Roadrunner505
Jul 06, 2021Tutor
RBS50 Incorrect Firmware Uploaded (v2.7.3.22)
I am trying to upgrade my satellite to the new firmware version V2.7.3.22 (article ID 000063811, https://kb.netgear.com/000063811/RBR50-RBS50-Firmware-Version-2-7-3-22) . However, I'm getting an er...
- Jul 06, 2021
NG has now corrected the file. Verified corrected.
Roadrunner505 wrote:I am trying to upgrade my satellite to the new firmware version V2.7.3.22 (article ID 000063811, https://kb.netgear.com/000063811/RBR50-RBS50-Firmware-Version-2-7-3-22) . However, I'm getting an error saying that the firmware version is incorrect. When I open the zip file, the .img file is "RBR50-V2.7.3.22.img". Is the file name wrong or was the wrong file uploaded by Netgear?
Jul 06, 2021Guru - Experienced User
This isn't working for you at all?
Might try powering OFF your ISP modem/ONT and router for 30 seconds then back ON. Clear out all browser caches as well.
Is odd that some are getting the file and some don't. I was able to get this after getting home from work today.
daboss54 wrote:not working here either no correction from Netgear
daboss54
Jul 06, 2021Aspirant
can you send the corrected file for rbs50 thanks
- FURRYe38Jul 06, 2021Guru - Experienced User
I'm using Opera GX. I just noticed that while on my Mac Laptop, the browser downloaded the wrong sized file. I selected the file again from the same link and it then downloaded the right sized file. Can you try this as well? Try Opera GX using the link from here:
Just select the RBS50 file a couple of times and see if it will download the right size file. The file should be 23MB, Not 44MB.
- thatkid2dieselJul 06, 2021Initiate
That link took care of it for me. File was 22,592k. Previous file was 45,127k. I was able to use Chrome, the browser I tried opening with before. All is good now. Thank you for your help.
:smileywink:
