erz
Aug 13, 2020Aspirant
RBS50 is loosing connectivity on certain protocols.
Hello community, I was super satisfied of the orbi solution since February, quite no issue at all but for 2 or 3 days I'm getting the only strange issue I have quite everyday. RBR50 and RBS50...
- Aug 13, 2020
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Aug 13, 2020Guru - Experienced User
Mstrbig
Aug 13, 2020Master
I really don't know of anything on the Orbi router or satellites that could cause this, if you've made no changes. If the PC server issue is the only device having a problem, I'd be looking more at that. Depending on what OS the PC is running, it could be firewall settings on the PC. Temporarily turn off the firewall and see if it corrects the issue.
