erz
Aug 13, 2020Aspirant
RBS50 is loosing connectivity on certain protocols.
Hello community, I was super satisfied of the orbi solution since February, quite no issue at all but for 2 or 3 days I'm getting the only strange issue I have quite everyday. RBR50 and RBS50...
- Aug 13, 2020
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Aug 13, 2020Guru - Experienced User
erz
Thank you very much for the configuration suggestion, i've just lost the entire message I wrote :( so sorry for being so quick to reply. But you pointed it my channel are autos and some configuration you suggest differ a bit from mine 20/40 by example. So i'll try your settings suggestion and keep posting if anything get better in the following days.
I don't think the machine iis the cause because every services are running fiine once orbi has reboot. Most are docker containers that never been faulty for years and the hypervisor seems fine for at least this time.
Thank you again for the quick help and suggestion with really comprehensive answer.
