manxdoc
Mar 18, 2021Guide
RBS50 issue with backhaul status & config sync
Hi all I have in the past successfully converted a RBK50 into a RBS50 The last time I did but, in the backhaul status I got the "config sync" message The converted RBS however works fine. It get...
manxdoc
Mar 27, 2021Guide
An update.
Things have somewhat improved. The RBS50 (ex-RBR50) is now connected to the Router with a 5G connection and devices like phones and laptops can connect to it and work fine but the backhaul status still reads "Config Sync"
The satellite is present in the Attached Devices with its own IP address but if I go to Update Firmware it's not there and the FW can't be updated either online or manually.
I read somewhere that under Advanced Setup > Wireless Settings > Backhaul Password, the Cofig Sync issue can be fixed by by generating a new password but it didn't work for me
Can anyone suggest a way to connect to the satellite so that I could try to reinstall the FW?
If I use Putty in telnet it let me just access the Router
Thanks
