kagler
Jul 06, 2021Aspirant
RBS50 issues with Firware V2.7.3.22 - Firmware incorrect
I have had an RBR50 +1 RBS50 satelite that had been working nearly flawlessly for some time,,,,until Firware V2.7.2.104. Devices being blocked from the internet when connected to the satelite, like ...
evilcougar
Jul 07, 2021Aspirant
After this upgrade, on top of the bugs already mention, also noted the following:
- Under Advanced -> Advanced Setup -> Web Services Management.
All the Remote Management options have disappeared. Has this been removed intentionaly I wonder.
- Also noted in orbi app (for IOS), under Settings -> Anywhere Access" "Out-Of-Home Controls" turned itself back on, I had this turned off before upgrade. That to me is a major concern, do we have to check every setting each time we do an upgrade now!!!
- Along with the other known bugs that have not been addressed, as mentioned in this thread.
Is Netgear going to take software upgrades more seriously in future? The constant simple QA oversights, ie mismatch firmware, changing configuration, not addressing major bugs etc are starting to get tiresome.
Seriously, unless there are some assurances there will be better QA before releasing software updates, and addressing bugs in a timely manner, I'm just going to buy another router from somewhere else.
tagteam
Jul 08, 2021Virtuoso
evilcougar wrote:- Also noted in orbi app (for IOS), under Settings -> Anywhere Access" "Out-Of-Home Controls" turned itself back on, I had this turned off before upgrade. That to me is a major concern, do we have to check every setting each time we do an upgrade now!!!
That is, indeed, odd. I just checked my Orbi app (iOS) and that setting is still turned off; nothing else appears to have changed with the update.
