kagler
Jul 06, 2021Aspirant
RBS50 issues with Firware V2.7.3.22 - Firmware incorrect
I have had an RBR50 +1 RBS50 satelite that had been working nearly flawlessly for some time,,,,until Firware V2.7.2.104. Devices being blocked from the internet when connected to the satelite, like ...
CrimpOn
Jul 08, 2021Guru - Experienced User
evilcougar wrote:After this upgrade, on top of the bugs already mention, also noted the following:
- Under Advanced -> Advanced Setup -> Web Services Management.
All the Remote Management options have disappeared. Has this been removed intentionaly I wonder.
I just now installed v2.7.3.22 on my spare Orbi RBR50. Web Services Management appears as it always has. (see attached image). With only one device connected to this Orbi (my Double NAT test bed), I have not noticed any other changes.
Continue to be amazed that people can install the exact same firmware on Orbi routers and wind up with different settings.
Some users may need a factory reset and setup from scratch if they encounter odd problems like browser items missing or not appearing.
Be sure to clear out all browser caches before entering the RBRs web page.
Try a different browser as well.
Most cases this isn't a FW issue.
- evilcougarJul 08, 2021Aspirant
After reading the replies, looks like I'll have to do a factory reset. Will do that later today.
Thanks all for the good replies and comments, I normally would not post, and I know I've probably sent the original post off on a tangent, but I was just getting frustrated after satellite firmware install error, we are in lock down over here emotions are running high at the moment. :smileyhappy:
- FURRYe38Jul 08, 2021Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemI recommend doing a base back up configuration file. One with just the basics setup. Then if you want to enable Access Controls, Armor, Circle ,Traffic Meter and such then do another that includes all that.
