sujay265
Jul 21, 2021Tutor
RBS50 keeps disconnecting frequently from RBR
Hello Folks, I have an Orbi RBK52 system. A while ago the RBR failed and netgear sent a replacement RBR. Ever since I connected to the existing original RBS I am facing frequent disconnection ( the...
michaelkenward
Jul 22, 2021Guru - Experienced User
sujay265 wrote:
Hello Folks,
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk & Non-Orbi). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
