sujay265
Jul 21, 2021Tutor
RBS50 keeps disconnecting frequently from RBR
Hello Folks, I have an Orbi RBK52 system. A while ago the RBR failed and netgear sent a replacement RBR. Ever since I connected to the existing original RBS I am facing frequent disconnection ( the...
Jul 23, 2021Guru - Experienced User
Is FW version on RBS the same as on RBR?
What is the distance between the router and satellite(s)📡? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
sujay265 wrote:
Hello Folks,
I have an Orbi RBK52 system. A while ago the RBR failed and netgear sent a replacement RBR. Ever since I connected to the existing original RBS I am facing frequent disconnection ( the RBS drops connection every 20 mins. ) the connection between the RBR ant RBS is wired so there is no question of weak wireless signal between then both.
Please can anyone help me with this situation. Firmware version V2.7.3.22. The problem is only with the RBS, as all the devices connected to RBS gets disconnected from internet, while the RBR is perfectly fine.
Regards
Sujay
sujay265
Jul 23, 2021Tutor
Hello Furry,
My home is about 2400 sq.ft. single floor. The distance between the RBR and RBS is 45 feet wired ethernet connection.
I am using manual channels 2.4GHz = channel 11 and 5 GHz = channel 48
I have the Implicit Beamforming, MU-MIMO and Fast Roaming disabled.
I did a factory reset on both the RBR and RBS, apparently that did not fix the issue.
The firmware version on both the RBR and RBS are same V2.7.3.22
Yes there are atleat 10 Wifi neighbouring SSID that i can see.
The problem is frequent RBS discnnection every 30 min, i have to reebot the RBS unit to get it back online, which takes 8 minutes. This is so frustrating which this happens in the middle of a meeting. Please somone help.
- FURRYe38Jul 23, 2021Guru - Experienced User
Is the RBS directly connected to the back of the RBR or is there a LAN switch in between the RBR and RBS?
Does this disconnection happen if you move the RBS to say 30 feet from the RBR and disconnect the ethernet cable from the RBS and let it connect wirelessly?
