Transcendence
Jul 05, 2019Aspirant
RBS50 keeps disconnecting
Hi all, so I've been looking around the internet for solutions to this (seems like MANY people have this issue). I have my RBR50 set up next to my modem (Netgear CM600) and my RBS50 set up in my bedr...
Jul 13, 2019Guru - Experienced User
The distance mabye too far based on buiding materials.
Can you do this as a quick test to see if the backhaul speeds get higher? Move the RBS to with in 10 feet of the RBR. Run the same test. Speed should be over 1300Mbps...
Transcendence wrote:Hi all, so I've been looking around the internet for solutions to this (seems like MANY people have this issue). I have my RBR50 set up next to my modem (Netgear CM600) and my RBS50 set up in my bedroom about 50(?) feet away. I maintain a wired connection to my laptop via ethernet to the RBS50. Ever since buying it (November 2018), I've been experiencing periodic disconnections once every few hours.
Fixes that I've tried:
- updating to the most recent firmware (via web interface),
- lowering the 2.4ghz and 5ghz power settings (via web interface), and
- changing the SIDs for both channels (via telnet, web interface)
as well as factory resetting and doing all three of the above. Since failing all of those methods, I've just shut off the RBS50 and have had no issues...can someone please help?
