eliwoo
Apr 01, 2022Star
RBS50 limited to 100 Mbps over cat6
As the post says I have a machine networked via Cat5e to a RBS50 satellite which is itself networked to a RBR40 via Cat6 cable. I get Sonic gigabit service but only receive 100 Mbps through the ...
- Apr 03, 2022
eliwoo wrote:
well the 30 foot Cat5e cable consistently delivers 1000Mbps when plugged directly into my workstation.
So i feel like the cable is not the issue. -----Some devices are more tolerant of sketchy cables. So while it might work on the workstation, its possible that the cable ends/cable itself is still sketchy/bad. I've seen this happen several different times. the 6ft test with a decent quality cat 6 cable is ideal.
eliwoo
Apr 03, 2022Star
btw i actually measured the run of the cable and its actually about 60 feet.
so twice what i had estimated. (the two orbis are about 30 feet apart in a straight line, but the actual cable runs around doorways and such.
CrimpOn
Apr 03, 2022Guru - Experienced User
Cat5e cable is rated to support 1000Base-T at a length of 328ft. (including 10m of patch cables). A 60ft. run is trivial.
https://en.wikipedia.org/wiki/Category_5_cable
If it supports 1000/Full directly to the PC, then the cable should be OK.
The satellite supports 1000/Full using a short Ethernet cable directly to the router. It should be OK.
It's not the RJ45 jacks, because all four act the same way.
In other words, this cannot be happening. I might go for a kink or something that stresses the cable when it is plugged into the satellite, but not when plugged into the PC. Damn. Damn. Damn.
- eliwooApr 03, 2022Star
the only variable here is the short cable i tested with the RBS was cat6, while the long cable is Cat5e.
is there anyway the RBS just doesnt like the cat5e?
- plemansApr 04, 2022Guru - Experienced User
I've seen cheap cat 5e cables that would work in gigabit when connected to computers but would fail and only connect at 10/100mbps when connected to routers/switches. I'd upgrade to a decent quality cat 6 cable for that run
- eliwooApr 04, 2022Star
okay seems like this is the only viably solution at this point. thank you both for helping me out. ill post an update when i replace the cable. I really hope thats the issue.
