gr8sho
May 12, 2019Virtuoso
RBS50 Magenta ring displayed temporarily during cold start with v2.3.1.x firmware
The following describes something I believe is working as designed. Looking for confirmation.
I've noticed on at least two different occasions the RBS50 will display magenta ring while it's i...
May 16, 2019Guru - Experienced User
I saw this as well when setting up a RBR and RBS50 system. I was concerned at first however I waited and then the BLUE led appeared.
I presume it's nothing to be overly concerned about. As long as you get the BLUE led and it eventually turns off, you'll be fine.
