gr8sho
May 12, 2019Virtuoso
RBS50 Magenta ring displayed temporarily during cold start with v2.3.1.x firmware
The following describes something I believe is working as designed. Looking for confirmation.
I've noticed on at least two different occasions the RBS50 will display magenta ring while it's i...
CrimpOn
May 16, 2019Guru - Experienced User
gr8sho wrote:
I've noticed on at least two different occasions the RBS50 will display magenta ring while it's initializing after a cold start (plugging in the box to AC power). The bootup process is fairly lengthy to begin with, and towards the end of it, the LED ring will display magenta, and then after about another minute will turn blue indicating the bootup process has completed.
Netgear's description of the Orbi LED and Ring colors (https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean ) seems to indicate that turning magenta for at least a short time is normal before it turns blue for 10 seconds, and then goes off.
- gr8shoMay 17, 2019VirtuosoYeah, but it seems the scenario could handled better. For instance, if a config sync is needed, do it while the device is still initializing and suppress the error state indicator until the routine completes. I can easily see people giving up when they see the ring putting them back at square one.
In the example I provided, I believe the reset was successful because the second reboot did not go through the magenta state.
