aibanez2797
Jul 17, 2019Aspirant
RBS50 makes network unstable
A while ago, I bought a RBR50/RBS50 combo with one router and two satellites. From the first day I had it, I couldn't use one of the satellites. It was running older firmware than the router and th...
Jul 17, 2019Guru - Experienced User
You don't need to use TFTP.
Just factory reset the RBS after you have downloaded the necessary files. Connect 1 wired PC to the back of the RBS and wait for the PC to get an IP address, should be 192.168.1.something. Open a web browser and input 192.168.1.250. This should open the RBS web page. Admin and PW is password. Once in, send the v2.0.0.74 FW file. After this loads, continue to loading the v30 FW file for the RBS. should be able to go directly to v30 after v74.
CrimpOn
Cool. I did not realize the satellite would give devices an IP address when it is not connected to the router. Great tip about the 1.250 web address.
- FURRYe38Jul 17, 2019Guru - Experienced User
Ya I had wondered about that a while back. I happend to do a reset and figured, lets see what happens. Sure enough. PC got an IP address and the gateway IP worked for logging to the RBS. Nice safety feature. :smileywink:
