anon_user_221
Apr 13, 2021Aspirant
RBS50 Manually Configure IP Address
Hello, I have a RBR50 which I manually configured the LAN interface and changed to AP Mode. Now I cannot change the IP on the LAN interface. However, I cannot configure the RBS50 LAN interface ...
CrimpOn
Apr 13, 2021Guru - Experienced User
When an Orbi router is placed into Access Point (AP) mode, there are many features which no longer function.
The router, satellites, and every other device will get their IP assignment from whatever is acting as the "router".
The Orbi no longer provides DHCP to client devices and there is no longer a difference between the WAN and LAN IP spaces.
Maybe I misunderstand what the goal is. Perhaps some more explanation of what the end result is supposed to be?
