Jmthorp
Dec 05, 2018Tutor
RBS50 no WiFi clients/connections
I have an RBR50, RBS50 and later added a RBW30. I’m not sure my RBS ever allowed wireless client access (thus why I bought the RBW30). Firmware V2.2.1.210 now. I have had continuous wireless connecti...
Dec 06, 2018Guru - Experienced User
I would try a factory reset on the RBR and RBS and set up from scratch.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Jmthorp
Dec 06, 2018Tutor
Thank you for your input:
Modem is Arris Surfboard S6183.
It's been a while since I've done a factory reset but symptoms existed prior to my last reset. I'll resort to that at some point soon when I can alot the time for getting everything back online :(.
In the mean time it's easy to test the other settings. Thank you.
- FURRYe38Dec 06, 2018Guru - Experienced User
If it's been a while and you haven't done a reset, may be time for one. Other report having good operation after a reset and setup from scratch.
You should be able to get it running soon after.
Let us know how it goes.
