Jmthorp
Dec 05, 2018Tutor
RBS50 no WiFi clients/connections
I have an RBR50, RBS50 and later added a RBW30. I’m not sure my RBS ever allowed wireless client access (thus why I bought the RBW30). Firmware V2.2.1.210 now. I have had continuous wireless connecti...
Jmthorp
Dec 06, 2018Tutor
Thank you for your input:
Modem is Arris Surfboard S6183.
It's been a while since I've done a factory reset but symptoms existed prior to my last reset. I'll resort to that at some point soon when I can alot the time for getting everything back online :(.
In the mean time it's easy to test the other settings. Thank you.
Dec 06, 2018Guru - Experienced User
If it's been a while and you haven't done a reset, may be time for one. Other report having good operation after a reset and setup from scratch.
You should be able to get it running soon after.
Let us know how it goes.
