jayb1967
May 09, 2021Aspirant
RBS50 not connecting, needs firmware update, help please!
Already own a RBR50 with 1 RBS50 satellite. Purchased used RBS50's to add to system. One was recognized but not connecting to system. I am unable to udate the firmware or properly connect. Suggesi...
jayb1967
Thank you all. I def did the 'Factory Reset' on the satellite. Pic # one (1) is of the Orbi app showing the available network [Internet -> RBR50 (w/ green dot) -> Orbi Satellite-1 (w/green dot) & Satellite-2 (w/purple dot). Pic # two (2) was from orbilogin.com on the 'Attached Devices' screen. I see this:
| Status | Device Name | IP Address | MAC Address | Connection Type | Connected Orbi | Backhaul Status | 1 |
CrimpOn
May 09, 2021Guru - Experienced User
The forum software package that Netgear uses does not display images placed in-line using the Photos icon until they are approved by a forum moderator (which can take hours or days). Images 'attached' using the Browse button in the lower left are available immediately.
Can you be more specific about these two satellites. i.e. what does "recognized" mean? Do they both behave the same, or are there differences between them?
