Jobono
Jul 29, 2018Aspirant
RBS50 Not emitting WiFi
Hey guys,
I am completely stumped at the problem.
Reboots. Firmware upgrades. Downgrades. I feel like I've done the lot.
I've had my Orbi for about a year an a half now, but apart f...
Jul 29, 2018Guru - Experienced User
Disable the Arlo device, turn them OFF.
Do a factory reset on the Orbi router and have a wired PC connected to the router. Walk thru the set up wizard and give some new SSID name and simple password. Use something unique. Don't add any satellites. Set the WPA security to Disable or OPEN temporarily. When you get to the end. Look for this new SSID name and PW. Does it appear on a wireless device? If you do, go back in and set WPA2 to AES. Does any wireless device see and connect here?
Jobono
Jul 30, 2018Aspirant
Yep, all good. I've got to that point. Not to sound dumb, but whats next?
I've tried connecting to the satellite, but no luck. Still doesn't seem to want to connect.
- JobonoJul 30, 2018Aspirant
Just to add on... so when i connect to the Satellite IP (when im on the network) - it says its emitting wifi, but nothing is connecting.
