Jobono
Jul 29, 2018Aspirant
RBS50 Not emitting WiFi
Hey guys,
I am completely stumped at the problem.
Reboots. Firmware upgrades. Downgrades. I feel like I've done the lot.
I've had my Orbi for about a year an a half now, but apart f...
Jul 30, 2018Guru - Experienced User
So connections with the router is good?
Connecting the satellite is good, however when you connect devices to the satellite, your not getting any internet access?
- JobonoJul 30, 2018AspirantThat's correct. Everything is fine with the router.
Ethernet connection is fine with the Satellite. Supposedly it SAYS it's emitting WiFi, but nothing is connecting.
There's the 'hidden network's that I'm detecting that connects the router and satellite and that's a full bars..- FURRYe38Jul 30, 2018Guru - Experienced User
And was a full reset done on the satellite and re-added? if so, I resume this satellite is probably bad and needs to be replaced. I would contact NG support and or the forum moderator and see what can be done. Ask for an RMA.
- JobonoJul 30, 2018AspirantSigh. Yep. Did the reset and readd. I was afraid that the satellite died out.
Thanks anyway!
