Jobono
Jul 29, 2018Aspirant
RBS50 Not emitting WiFi
Hey guys,
I am completely stumped at the problem.
Reboots. Firmware upgrades. Downgrades. I feel like I've done the lot.
I've had my Orbi for about a year an a half now, but apart f...
Jobono
Jul 30, 2018Aspirant
That's correct. Everything is fine with the router.
Ethernet connection is fine with the Satellite. Supposedly it SAYS it's emitting WiFi, but nothing is connecting.
There's the 'hidden network's that I'm detecting that connects the router and satellite and that's a full bars..
Jul 30, 2018Guru - Experienced User
And was a full reset done on the satellite and re-added? if so, I resume this satellite is probably bad and needs to be replaced. I would contact NG support and or the forum moderator and see what can be done. Ask for an RMA.
