80rie
Sep 09, 2021Aspirant
Rbs50 not syncing
Hi. I’ve recently purchased used rbs50. After trying to sync to rbk50, both through the router and original satellite, all I get on it is a flashing white light. I’ve tried resetting and the other fixes.
The only thing I can think of is.
I’m in Australia using Australian rbk50. This rbs50 is from USA. Using a power adapter plug. Is this a regional issue.? Not sure what else to try.
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
What Firmware version is currently loaded? Be sure the RBS is loaded with same version of FW thats on the RBR.
- 80rieAspirantThe rbr50 is on 2.7.3.22. I’m not sure what firmware version rbs50 is on. I bought that one used on eBay.
I tried updating via cable to pc using tftp and command prompt but don’t seem to be getting anywhere.
Maybe there is an issue , being rbs 50 is from USA and my rbk50 is Australia?? But I didn’t expect that to be problem.- FURRYe38Guru - Experienced User
