acky
Dec 17, 2017Tutor
RBS50 Orbi satellites do not have IP address, do not show up in GNU do have blue light
I have the Orbi RBK50 with 2 satellites (RBS50). The two satellites are connected (have a blue lights on both) but do not show up in the GNU as connected satellites and are running old Firmware with ...
- Dec 17, 2017
Good.
Go to the Netgear website and download the RBS version of the software (there's a firmware load for the router and a different load for the satellite.) Save it to your computer. Unzip it if necessary.
Then use a web browser to navigate to the satellite. http://<IP ADDRESS OF SAT> Use the IP address you just found.
Login. You might need to use the default password combo (admin/passsword) if your own password doesn't work.
Click on firmware update. Upload the file you downloaded earlier.
st_shaw
Dec 17, 2017Master
A couple questons. When you did the reset, did you hold in the button with a paperclip for 30 - 60 seconds until the power LED started blinking amber? Did you go through the "add orbi satellite" process on the router GUI after the reset?
You should be able to find the IP address of the satellites (assuming they have one) from a laptop or desktop. Open a command window and type "arp -a" and you will get a long list of known IP address and mac addresses. This works on Windows or OSX.
The satellite's mac address is printed on the label on the bottom of the satellite. The 2.4 and 5 GHz radios each have a mac address. On mine the mac for the 5 GHz is the same, except for the last two digits, which are higher by 2. Example, 2.4G: 00:01:02:03:04:AD and sat:00:01:02:03:04:AF
If you can find the IP address this way, then you can log into the satellite directly and manually update the firmware.
- ackyDec 17, 2017Tutor
Thank you for your help!
I did hold the reset with the paperclip for 30-60 seconds for the reset until it was blinking amber.
I've tried "Add satellite" through both the GNU and the app. It can't find it either way but if I unplug it and plug it back in it will connect with a blue light on its own.
Found the IP address - matched it to the MAC address.
How do I use the IP address to now log into the satellite to try and update the firmware?
- st_shawDec 17, 2017Master
Good.
FANTASTIC!!!!
Both satellites are running firmware that matches the router's version and they both now appear in the connected satellite list!!!
Thank you so much for your help!!!
