acky's avatar
acky
Tutor
Dec 17, 2017
RBS50 Orbi satellites do not have IP address, do not show up in GNU do have blue light
I have the Orbi RBK50 with 2 satellites (RBS50). The two satellites are connected (have a blue lights on both) but do not show up in the GNU as connected satellites and are running old Firmware with ...
  • st_shaw's avatar
    st_shaw
    Dec 17, 2017
    Good.
    Go to the Netgear website and download the RBS version of the software (there's a firmware load for the router and a different load for the satellite.) Save it to your computer.  Unzip it if necessary.
    Then use a web browser to navigate to the satellite.  http://<IP ADDRESS OF SAT>  Use the IP address you just found.
    Login.  You might need to use the default password combo (admin/passsword) if your own password doesn't work.
    Click on firmware update.  Upload the file you downloaded earlier.
