acky
Dec 17, 2017Tutor
RBS50 Orbi satellites do not have IP address, do not show up in GNU do have blue light
I have the Orbi RBK50 with 2 satellites (RBS50). The two satellites are connected (have a blue lights on both) but do not show up in the GNU as connected satellites and are running old Firmware with ...
- Dec 17, 2017
Good.
Go to the Netgear website and download the RBS version of the software (there's a firmware load for the router and a different load for the satellite.) Save it to your computer. Unzip it if necessary.
Then use a web browser to navigate to the satellite. http://<IP ADDRESS OF SAT> Use the IP address you just found.
Login. You might need to use the default password combo (admin/passsword) if your own password doesn't work.
Click on firmware update. Upload the file you downloaded earlier.
acky
Dec 17, 2017Tutor
Thank you for your help!
I did hold the reset with the paperclip for 30-60 seconds for the reset until it was blinking amber.
I've tried "Add satellite" through both the GNU and the app. It can't find it either way but if I unplug it and plug it back in it will connect with a blue light on its own.
Found the IP address - matched it to the MAC address.
How do I use the IP address to now log into the satellite to try and update the firmware?
st_shaw
Dec 17, 2017Master
Good.
