Angelo1112
Jun 09, 2020Aspirant
RBS50 Performance
Setup: Orbi68 RBR50 & 1 RBS50 Spectrum ISP Router is about 80' from my desktop and the satellite is roughly at mid-distance between router and desktop location. The issue is this: the satellite is ...
- Jun 10, 2020
Hello Furrye38...
Thanks for your help on my reported issue. The following is the information requested:
What does N mbs and 2N mbs mean? Simply that with the satellite at the optimum location (see below) and set upright my throughput speed in mbs is N and when it's set on its belly/side the throughput is roughly twice when set upright. The actual speed range when upright is 70-100mbs and on its belly/side it is 130-170mbs. Due to the satellites odd/oblong shape the contact area when on its belly/side with the surface of what it is set on is small therefore subject to move with slightest touch. So I have to secure it without blocking its antennas. I have no qualm with the throughput I am getting at the desktop. Of course getting a higher throughput would always be a good thing since at the router location I get over 350mbs.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It is branded as Spectrum ModelE31U2V1 DOCSIS 3.1 eMTA (who manufactures it for Spectrum I have no idea...not indicated on the case or on the product label)
What is the size of your home? Sq Ft? The home is 3,890 sq. ft. with 2 stories with roughly 60% of its area on the lower level where my office is located. The house is approximately 120', not a straight line from one end to the other on the lower story.After measuring, the satellite is just short of 55' from the router and my desktop is 45' from the satellite. Where the satellite is located provides the best throughput at the desktop i.e. if I moved the satellite closer to the router or the or closer to the desktop throughput goes down.
Any Wifi Neighbors near by? If so, how many? I typically pick up 2 or 3 of my neighbors wifi signal. The lots in our development are large, minimum size is half acre, some are multi-acre; ours is over an acre.Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings This has been enabled. Don’t know if it is making a difference in the throughput.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).I will fiddle and try the suggested changes and see if I get better results. Please understand that I did not consider the problem could be due to how the antennas are arranged in the packaging. I thought it was design issue. It was not because I am cheap; not willing to pay for service support as someone suggested in a response to my post. I was simply trying to bring it to Netgear’s attention and if they really had a fix for a design issue why should I have to pay them to correct their problem. I greatly appreciate everything, the suggestions, education and the time you took to respond to my post. All the best to you.
CrimpOn
Jun 09, 2020Guru - Experienced User
Angelo1112 wrote:I was informed by Netgear they could correct this issue but since the 90 day free support has expired January 2020 I would need to first purchase a 1 year service contract for $189 for them to correct the issue. I assume the only thing they could do is tweak the satellite firmware to address the issue. The FCC filing provides photos of the internals of the RBR50 showing the antennas.
https://fccid.io/PY316200341/Internal-Photos/Internal-Photos-RBR50-RBS50-rev-pdf-3926901.iframe
Good thing that you did not "accept the offer."
- There is nothing the firmware can do about the antenna orientation. By placing the unit on its front/side, you changed the antennas from vertical to horizontal. This may enhance performance in some directions and reduce performance in other directions.
- Were you directed to this web site to consider purchasing support:
https://www.netgear.com/mynetgear/Gearhead/subscribe.aspx
This is the "official" Netgear subsidiary that offers technical support. Notice that in the US there are plans for 6 months, 12 months, and 24 months. This is an offering similar to GeekSquad from BestBuy. "We'll help you with any product, not just from Netgear." - Or, were they attempting to sell an extended warranty or extended service plan, which according to the Netgear web site, must be purchased within 90 days of buying the unit?
Angelo1112
Thanks for the reply. The 90 days from purchase registration expired this past January. Since what was provided in the warranty coverage was that I had voice or chat support on the product for 1 year from purchase. But the support website indicated the opposite. So I placed the call to get clarification. After I explained the situation, which took some time since the person on the other end English was not her first language, I was put on hold. When she came back to the call she started by saying they could fix the problem but since my free coverage had expired I needed to buy a support plan. Before she put me on hold I sensed what would be coming down. The 2 year deal was initially offered followed by the 1year option and the end a 6 mos. option each rejected when quoted. When it became clear I wasn't going to buy I got quick brushoff but ending with a promise she would be sending me some possibly helpful info. It was never sent. Not the experience I was expecting. Have bought lots of gear from Netgear over the years.
