Angelo1112
Jun 09, 2020Aspirant
RBS50 Performance
Setup: Orbi68 RBR50 & 1 RBS50 Spectrum ISP Router is about 80' from my desktop and the satellite is roughly at mid-distance between router and desktop location. The issue is this: the satellite is ...
- Jun 10, 2020
Hello Furrye38...
Thanks for your help on my reported issue. The following is the information requested:
What does N mbs and 2N mbs mean? Simply that with the satellite at the optimum location (see below) and set upright my throughput speed in mbs is N and when it's set on its belly/side the throughput is roughly twice when set upright. The actual speed range when upright is 70-100mbs and on its belly/side it is 130-170mbs. Due to the satellites odd/oblong shape the contact area when on its belly/side with the surface of what it is set on is small therefore subject to move with slightest touch. So I have to secure it without blocking its antennas. I have no qualm with the throughput I am getting at the desktop. Of course getting a higher throughput would always be a good thing since at the router location I get over 350mbs.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It is branded as Spectrum ModelE31U2V1 DOCSIS 3.1 eMTA (who manufactures it for Spectrum I have no idea...not indicated on the case or on the product label)
What is the size of your home? Sq Ft? The home is 3,890 sq. ft. with 2 stories with roughly 60% of its area on the lower level where my office is located. The house is approximately 120', not a straight line from one end to the other on the lower story.After measuring, the satellite is just short of 55' from the router and my desktop is 45' from the satellite. Where the satellite is located provides the best throughput at the desktop i.e. if I moved the satellite closer to the router or the or closer to the desktop throughput goes down.
Any Wifi Neighbors near by? If so, how many? I typically pick up 2 or 3 of my neighbors wifi signal. The lots in our development are large, minimum size is half acre, some are multi-acre; ours is over an acre.Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings This has been enabled. Don’t know if it is making a difference in the throughput.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).I will fiddle and try the suggested changes and see if I get better results. Please understand that I did not consider the problem could be due to how the antennas are arranged in the packaging. I thought it was design issue. It was not because I am cheap; not willing to pay for service support as someone suggested in a response to my post. I was simply trying to bring it to Netgear’s attention and if they really had a fix for a design issue why should I have to pay them to correct their problem. I greatly appreciate everything, the suggestions, education and the time you took to respond to my post. All the best to you.
Jun 10, 2020Guru - Experienced User
"If the satellite is set in its designed stand mode performance is N mbs and if set on its belly/side performance is almost 2N mbs"
Angelo1112 wrote:Setup: Orbi68 RBR50 & 1 RBS50 Spectrum ISP Router is about 80' from my desktop and the satellite is roughly at mid-distance between router and desktop location.
The issue is this: the satellite is in the optimum location from a performance and acceptable home aesthetics standpoint. If the satellite is set in its designed stand mode performance is N mbs and if set on its belly/side performance is almost 2N mbs. This suggests to me it is a design or firmware issue. I was informed by Netgear they could correct this issue but since the 90 day free support has expired January 2020 I would need to first purchase a 1 year service contract for $189 for them to correct the issue. I assume the only thing they could do is tweak the satellite firmware to address the issue. I respectfully refused the offer. I would like to know is there anything I can independently do to duplicate whatever support would be doing to address the issue remotely? I did upload the latest available firmware for the router: V2.5.1.16.
Angelo1112
Jun 10, 2020Aspirant
Hello Furrye38...
- FURRYe38Jun 10, 2020Guru - Experienced User
And the problem may be with your system and not a design issue as others including myself haven't experience this our selves. Would be presumpuous to assume that this is a systemwide design issue...
- Angelo1112Jun 10, 2020Aspirant
Furrye8...
Your response has confused me. First, based mainly on your inputs I have closed the posted problem. I closed it because of the responses from you and others, the orientation of how the satellite is set in place on the installed surface affects throughput, due to how the antennas are arrayed in the housing. That the satellite empirically provides, in my case, significantly greater throughput when set on is side rather than when is set vertically as designed suggests a weakness in its design. That the unit set on its side makes it subject to be unstable unless secured in place is also empirically true. So how could it be my system? Try it with your system to see if you see the comparable results. What I have come to accept is that my unit despite this issue is not going to be fixed or replaced by Netgear. I will come up with something to secure it in place. No big issue as long as the throughput is acceptable.
