lbeck02
Nov 06, 2022Guide
RBS50 pulsing white AND power LED pulsing red. Other RBS50 ok
I have one RBR50 and 2 RBS50's. Firmware V2.7.4.24. One of the satellites is pulsing white and cannot be synced with the router. Plus the power LED is pulsing red. According to the user guide the p...
KevinLiT
Nov 07, 2022NETGEAR Moderator
Hello Ibeck02,
Thank you for your reply!
I understand that you have attempted a factory reset on your RBS50. However, if the procedure is not done correctly then the satellite will not reset.
Please follow the steps in the link below to successfully factory reset your RBS50:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Please let me know if you are still having issues.
Best,
Kevin
Community Team
lbeck02
Nov 07, 2022Guide
Yes. I did that before I posted here. I just tried again. Held the resit in for about 10 minutes. The ppower button continues to flash red. I also tried the following without success:
- Reinstalling firmware
- Powering on/off 5 times at one-second intervals
- Moving satellite to another location
- Swapping the Ethernet cables from the good satellite to the to the pulsing one
