billypatel
Mar 12, 2022Tutor
RBS50 pulsing white permanently
Hi I have had a orbi rb50 and an rbs50 working moslty ok for the past few years. This is in a uk household with virgin media. This week, the satellite has stopped working, and just pulses ...
Mar 12, 2022Guru - Experienced User
Does the satellite work if you hardwire it into the router?
- billypatelMar 12, 2022Tutor
when you say hardwire? you mean an ethernet cable from one of the router ethernet socket to the satellite? if so then yeah, i tried that, still pulses white.
- plemansMar 12, 2022Guru - Experienced User
the default ip address for a factory reset satellite is 192.168.1.250
any luck using that to access it if you have a hardwired in pc/laptop?
i cant browse to 192.168.1.250, i get a "site cant be reached" page in chrome
I can ping it though, so when i try to tftp FW to it, i get a "Transfer timed out" error when i attempt to PUT the img i downloaded from netgear support.
