billypatel
Mar 12, 2022Tutor
RBS50 pulsing white permanently
Hi I have had a orbi rb50 and an rbs50 working moslty ok for the past few years. This is in a uk household with virgin media. This week, the satellite has stopped working, and just pulses ...
billypatel
Mar 12, 2022Tutor
when you say hardwire? you mean an ethernet cable from one of the router ethernet socket to the satellite? if so then yeah, i tried that, still pulses white.
Mar 12, 2022Guru - Experienced User
the default ip address for a factory reset satellite is 192.168.1.250
any luck using that to access it if you have a hardwired in pc/laptop?
- billypatelMar 12, 2022Tutor
i cant browse to 192.168.1.250, i get a "site cant be reached" page in chrome
I can ping it though, so when i try to tftp FW to it, i get a "Transfer timed out" error when i attempt to PUT the img i downloaded from netgear support.
- billypatelMar 13, 2022TutorI’ve come to the conclusion that my satellite is dead. Spent many hours trying and it just remains pulsing white.
So… I want to replace the satellite. Can I purchase any orbi satellite or does it have to be an rbs50?- plemansMar 13, 2022Guru - Experienced User
RBS20, RBW30, RBS40, RBS40V, RBS50, RBS50Y
All those will integrate.
nmrpflash didn't work to downgrade the firmware?
