F13ND's avatar
F13ND
Rbs50 pulsing white
Hello All I have an RBR50 and RBS50 Router is at firmware 2.7.3.22 The router is fine but the satellite is pulsing white I can’t see the satellite in orbi app I have tried factory reset a b...
  • F13ND's avatar
    F13ND
    Nov 16, 2021
    I finally got my issue resolved
    So I was finally able to factory reset both satellite and router
    I started with the satellite and used a paper clip instead of a toothpick because it is a little easier to hold in the reset hole while the satellite was powered on.
    I held the paper clip in the reset hole for 3 mins then I unplugged the satellite ( usually I just press the power button )
    Not sure if unplugging is different then using the power off button.
    I continued to hold the reset button in for 2 minutes
    I plugged the power cable back in and continueed to hold the reset button in for an additional 3 mins
    so basically I held the reset button in for 8 minutes while unplugging/plugging the device in
    this allowed the satellite to factory reset.
    I was able to verify by connecting a computer via ethernet then ran arp -a from the command prompt to get the satellite ip
    I had set my laptop to
    IP 192.168.1.10
    subnet mask 255.255.255.0
    gateway 192.168.1.1
    here is what my arp -a looked like
    arp -a
    Interface: 192.168.1.10 --- 0x18
    Internet Address Physical Address Type
    192.168.1.1 b0-39-56-96-91-b0 dynamic <-- router
    192.168.1.250 b0-39-56-96-83-05 dynamic <-- satellite
    224.0.0.2 01-00-5e-00-00-02 static
    224.0.0.22 01-00-5e-00-00-16 static
    239.255.255.250 01-00-5e-7f-ff-fa static
    Once I tried to connect to satellite in a bowser it prompted for factory default credentials (admin/password)
    I tried the same procedure witht the router and it wouldn't work until I did
    5 mins with reset held in while powered on
    2 min power cable unplugged
    5 mins powered back on with reset held in
    So this time had to hold the reset button in for 12 mins
    hand started to get sore after holding the reset in for 12 mins straight.
    I had a friend help me to unplug the power cable and plug it back in .
    So after all of that I finally had the router and satellite back at the factory defaults.
    I setup everything with having the router and satellite plugged in beside the modem
    Only had ethernet cable running from modem to WAN port on the router
    It was working great even with the wifi back haul to the satellite
    Next I plugged in an ethernet cable from the satellite into the router and the back haul changed to ethernet and all was still good.
    Next I moved the satellite back to its orginal location and plugged all my wired devices back into satellite.
    Then everything broke again.
    I plugged a laptop back into the satellite and it said the back haul was connected with wifi and the status was stuck on "config sync"
    I noticed that the satellite had an ip address of 192.168.0.107 when it should have a 192.168.1.x address
    I found that all of the devices that connected to the satellite had 192.168.0.x addresses
    arp -a showing satellite with wrong ip range
    arp -a
    192.168.0.107 b0-39-56-96-83-05 dynamic  <-- satellite
    192.168.1.14 44-d2-44-5f-25-46 dynamic
    192.168.1.255 ff-ff-ff-ff-ff-ff static
    224.0.0.251 01-00-5e-00-00-fb static
    I finally figured this issue out that my son had plugged in a wireless router into the basement (TP-Link Archer C7) into one of the ethernet connections in my basement that was back hauled to the satellite.
    I unplugged this router and set a static IP reservation in the orbi admin page to 192.168.1.107 for the satellite and then powered the satellite on / off with the power button (only left it off for about 1 min)
    Once I powered it back on everything was back online and working as expected.
    Thanks everyone for the help on this one.
    I am now going to set static IP reservations for all of my wired devices.
