Manske
Oct 18, 2021Aspirant
RBS50, RBS20, ... Network interruption when connection goes from one satellite to the next
Dear community, I'm proud owner of an Orbi system and in general I'm really satisfied with the performance. One topic bothers me still with the system. We have 3 floors in our house (cellar,...
- Nov 04, 2021
Hey all, sorry for the late response, I was afk for a while.
Somehow the topic got resolved by itself. I didn´t change any setting, but now I can roam without interruption.
So from my point of view, the topic is solved!
CrimpOn
Oct 18, 2021Guru - Experienced User
Fast Roaming is enabled.?
Manske
Regarding the fast roaming, where can I activate it?
- FURRYe38Oct 18, 2021Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
- CrimpOnOct 18, 2021Guru - Experienced UserFast Roaming is on the Advanced tab advanced settings, wireless settings. I believe the default is "on", but wanted to double check.
- ManskeNov 04, 2021Aspirant
- FURRYe38Nov 04, 2021Guru - Experienced User
Enjoy.
