GrudgeMonkey
Aug 07, 2020Aspirant
RBS50 Replacment
I'm enjoying the RBK53 system, but I'd like to add another satellite. It seems that the RBS50 units included in the kit are no longer manufactured. Is there a newer model that will be compatible with...
Aug 08, 2020Guru - Experienced User
Also RBS20, RBW30, RBS50Y, EX7500, EX7700 and EX8000 are compatible. The EXs work as extenders only. No MESH support.
GrudgeMonkey wrote:I'm enjoying the RBK53 system, but I'd like to add another satellite. It seems that the RBS50 units included in the kit are no longer manufactured. Is there a newer model that will be compatible with my mesh?
