jsauger
Apr 14, 2022Tutor
RBS50 Router not available for firmware update
Hi, I was able to update my RBS50 Satellite manually (firmware v2.7.4.24) but the Router (firmware v2.7.3.22) will not update automatically and the device does not show up in the table of availa...
- Apr 14, 2022
Hi jsauger,
Updating the RBR50 is a little different than updating the RBS50. To update the satellite you need to first select it in the manual update tab. To update the RBR50 no selection is necessary. Just select the browse button and select the appropriate firmware option.
I included steps below to assist you in manually updating your router:
To update the firmware on your Orbi router, do the following:
- Return to http://orbilogin.com.
The BASIC Home page displays. - Go back to the Firmware Update page:
- Select ADVANCED > Administration > Firmware Update.
- Click the Manual Update tab.
- Click the Browse button, then locate and select the file that ends in .img on your desktop.
Be careful not to select the wrong file. - Click the UPLOAD button to upload the firmware file.
It takes a few minutes to finish the process.
The page adjusts. - Click the YES button to continue.
- After the Orbi router finishes updating, double-check the firmware version in the upper-right corner.
The firmware on your Orbi router is updated.
Best,
Kevin
Community Team
KevinLiT
Apr 14, 2022NETGEAR Moderator
Hi jsauger,
I understand that you are having trouble updating your RBR50. The automatic update is not showing for your RBR50 because new firmware updates are pushed out in increments to ensure the user's network compatibility.
Please navigate to the link below for the download file for your RBR50:
For more information on manually updating your RBK50 please navigate to the link below:
Please let me know if this helps!
Best,
Kevin
Community Team
jsauger
Apr 14, 2022Tutor
Thank you for the quick response!
The road block with manually updating is the Router does not show up as a device available for manual updates. It only shows for automatic updates, which won't trigger đ
- FURRYe38Apr 14, 2022Guru - Experienced User
As NG approves the FW for more wider use, I presume it will be made available via the Autoupdater service.
For now users can manually downgrade the FW and and apply it using the manual tab function.
