OwenK
Apr 22, 2022Aspirant
RBS50 Satellite - UnSecure Connection but fine on Main Router
RBR50 router with RBS50 Satellite Satellite is wired connection Router Firmware Version V2.7.3.22 - on both Auto update is selected, no idea when it updated Everything worked fine until a w...
- Apr 22, 2022
Hello OwenK,
I understand that you are having issues with the firmware version 2.7.3.22. The current RBK50 system firmware version is 2.7.4.24.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#RBR50%20(Orbi%20Router)%20Firmware%20Version%202.7.4.24
For more information on manually updating your RBK50 please navigate to the link below:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Please let me know if you are still having issues accessing those sites after upgrading!!
Best,
Kevin
Community Team
KevinLiT
Apr 22, 2022NETGEAR Moderator
Hello OwenK,
Best,
Kevin
Community Team
- OwenKApr 24, 2022Aspirant
updating firmware seems to have resolved the problem - was more than those 2 web sites, just used those as an example but is working (for now)
Not sure why if set to automatically update firmware, it had npt updated, but manual update of satellite and then router seems to have fixed it.
Thank you
- FURRYe38Apr 25, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- OwenKApr 25, 2022Aspirant
To my knowledge, I did mark it as solved - I accepted the solution and my original post shows solved. If there is something else for me to do, please advise - this is my first post and have no clue Thanks
